Rear Bench Seat Clip.
Little plastic bits and bobs are generally quite cheap from the dealer - so I would check with them and only look elsewhere if they indeed do turn out to be expensive. The dealer will be able to supply all parts.
Not sure exactly what part you mean, but the diagram here might help, is it on there ? If the item has a separate part number then it will be available from Lexus/Toyota. Sometimes the standard clips and things can be just a pound or so, but then again sometimes they can be more expensive, it's worth checking as edeath said.
Cheers Stevie should of had a look on there myself, it's on there and is only 1.11euro so about the same £, it's part number 72693. Thanks guys.
ok, cool. The full part number is in the right-hand table, i.e. 72693-20060, that's the number you'll need to give to Lexus/Toyota. Yeah it should only be about a pound. If you're lucky you might even be able to persuade a dealer to post it to you, if that will save a trip.
