Amp Bypass Cable
Hi All,
I'm currently in the process of installing my new double din unit into my IS200.
I need urgent help with fitting my amp bypass cable.
I have removed my original audio unit, removed the glove box cover and can see the amp on the passengers side wing.
But where the hell do i put the cable? :blink:
Has anyone got a walkthrough guide they can email me? sandipbansal_1@hotmail.com
I have PM'd AztecBandit1 as i came across one of his posts via the search facilty which said he had a walkthrough guide, but i'm waiting for his response.
Any help will be appreciated.
Regards,
S6NDP
Sandip Bansal
Hi All,
Regards,
S6NDP
Sandip Bansal
i,ve got the guide by aztecbandit on how to remove the amp, but can,t work out how to forward it to you. you need to unplug the top cable connector on the amp, and then plug that into your bypass lead. seems its a bit awkward to get at tho. if i work out how to forward guide i will hope this helps a bit.
Thanks for all your help guys...
Right pain in the arse but i got it all sorted.
A couple of bolts and a lot of wiggling the amp around and it soon came free. :hehe:
Big thanks also to Wozza and Eddie for sending walkthrough guides B)
  • 5 weeks later...
  • 11 months later...
