Sat Nav Screen Options
I have bought the center console from an Lexus SE - originally to do the usual sat NAV mod done a few times on here.
Since doing more research there are alot of sat nav's out there (most play MP4 through a usb or SD card so i revised the post).
I'll let you know how I go on this
Ok - so far so good. I have the thing apart.
Anyone got an idea how i can hard wire a Sat nav ?
Can I piggy Back with a scotch lock straight onto the cig lighter wires under the center console ?
Any Info would be good
Get the power source from the head unit loom. The Grey wire is the acc. & blue with a yellow strip is constant 12v.
*The bottom half of this guide is for GPS only
This actually helps alot - I was goign to use the HEAD loom to power the motor and tilt positions. I now wouldn't
need to circuit test for the ignition power supply.
I have found a way to run the SAT NAV really simply while still holding an internal fuse and relay. I have bought
an extension for the cigarette lighter that houses male and female at either end.
Apparently if I scotch lock from the cigarette loom I can plug the NAV straight in out of sight.
Also thinking about putting a USB female in the dash so I can do updates from a laptop without taking it
out of the car.
A plan is coming together !
Hi
Im a proud owner of an IS300 01 after many years of vws, audis and bmws. I am happy to say that I absolutely love the car and hope to have lots of happy time together :tomato:
Im in the process of changing my stereo to an aftermarket as I have the annoying error message when playing CDs otherwise I would be more than happy with the current sound quality.
I am thinking about purchasing the Harness:
http://www.carstereos4u.co.uk/lexus-stereo...4-2056556--.php
Do I need to buy anything else on top of this? (apart from the stereo of course)
but some people say that the rear speakers are 2 ohms and most aftermarket stereos are 4ohms which is apparenetly a problem?
I was also looking at the ipod interface:
http://www.carputer-shop.co.uk/ipod-digita...2186988f4652cbc
Can anyone provide some feedback
Thanks in advance..
  • 3 months later...
Finally completed the Sat Nav conversion using a Garmin 5000 system.
Everything works greeat and even plugged up ready for a rear view or DVD later through the composite cables !
Any Pics?
Planning on putting original Lexus sat nav in mine, will it connect into the existing wiring loom?
Damo090
