Instaling New Amp
hi, does any one know how to install a new amp onto a new head unit, and if it would be possable to put it where the stock lexus one is? i hav used the amp by pass lead to install the new head unit so i was wondering if it would be possable to get some sort of adaption lead for that? has any one done something similar? thanks
The easiest way to install a new amp, would be to ensure that your head unit has RCA outputs (phono). Then it is just a case of connecting these to the amp, along with a remote or switched 12v power supply to act as a signal to the amp to tell it when to turn on, and then the amp only requires a 12v feed from the Battery and a earth. You used to be able to get small amps like the OEM lexus one, although havent seen them around for a while. so i dont know if you will be able to find one to fit in the original space. As for connecting the the amp up using the loom that was there for the stock amp, it might be possible as all the wires should be there, but if you have removed the original wiring from the amp to the head unit and replaced it with the amp bypass cable, some additional wiring may be required. The other potenital problem is that the power and earth cables supplying the OEM amp may not be man enough for an after market amplifier.
All sounds a little confusing but i hope it helps
Kiff
Do you have an amp already? I doubt you find anything making half decent power that will fit where the factory one did. Get you're self an amp wiring kit from you local car audio shop. You'll want a minimum of 4 gauge cable IMO. A good kit will come with RCA's, Fuse holder & speaker cable. If the amps small enough you could put it under the passengers seat or else mount it in the trunk area. It's pretty straight forward but if you feel unsure about it get a professional to do it.
http://www.caraudiohelp.com/how_to_install...l_a_car_amp.htm
