Mist Switch
PHILLP
Just wondering if anyone knew what the Mist switch if for.
Its on the washer stick and had Mist off, Low Med & High..........ive turned it on and doesnt seem to do anything, the Manual doesnt even mention this.
Thanks in advance Phill
hi the mist part of the switch is if you pull the switch towards the steering wheel the wipers will operate once the low med high part is the intermitant part but you have to turn the switch to position one first for this to work hope this helps cheers tony
still abit confused, so does it control the operation of the wiper then??
thanks pp
Have to say that in 7 years I've never looked at what it says on the wiper stalk!
But all is as everyone has said above:
Pull stalk towards you, single wipe.
One notch down intermittent.
Two notches down continuous wipe.
Three notches down high speed continuous.
Grey ring adjusts the intermittent timing.
Button on the end operates the washer.
That's everything the wiper stalk does - no idea what the "mist" actually refers to but I'd imagine it's the single wipe as others have already said.
