Steering Noise & Stiffness
mylex
Hi! First i`m sorry if my english is not so good :crybaby: but hopefully i can explain my problem :)
I didn´t find anything by search so i have to make a question for you guys...
My steerin is at the moment very stiff and it wont centre it at all... also steering makes wery irritating :angry: screecky noise (like metal against to metal) when you turn steeringwheel left or right. There is no rattle or clunking sound what usually relates in brake pads (my pads are almost new). All these symptoms came up about 2 weeks ago. Does anyone have any idea what´s wrong with it???
I would check your lower swivel ball joints. I had a similar noise etc and found the drivers side one to be worn excessively, close to falling apart. Get the front end blocked up and see if the is any up and down movement in the joint.
I´m sure that it isn´t PS belt, beacouse that kind of noise can´t come from the belt. It`s like metal against metal SCRRREEEEK!! Not SQUEEK, like slipping belt.
I check that lower swiwel balljoint at end of this week and let you know was that it.
Thank you guys for these tips :)
