Pwr Snow Function Not Working
Hello everybody,
I have Lexus GS 430, but PWR and SNOW function is not working. When I set to PWR or SNOW, nothing is happening. I have checked fuse box, but it seems that everything there is ok. So now I really do not know what else should I check. Does anyone had a problem like this? Thank you in advance.
P.S. Sorry for my broken english.. :)
What are you expecting to happen? The differences are quite subtle, SNOW makes the throttle a little less sensitive, and PWR makes the gearbox shift down a little earlier and it will hang on to gears a bit longer. But the differences are not massive.........
Or is it actually doing nothing at all when you press the different switches? :)
As I told, it doing nothing at all... :(
Are there any light showing in the Dash ?....e.g, a green ECT symbol in power mode !
When I push the button to "PWR"/"SNOW" nothing is happening in the dashboard too.
Well, you are right........It is Broken !
Take it to a specialist. or Lexus dealer.
