Does anyone know if you can replace the bulbs in the electric window switches as mine are really dull, and also the rear fog light switch is this illuminated as mine works fine but the headlight adjuster is lit up but not the fog light switch.
This eBay seller will sort you out new LED ones that keep their colour unlike UK ones as resistor fitted to them. I've just done all the dash blue with them.
LINK and eBay name.
warden_jp2002
http://cgi.ebay.co.uk/2pcs-T3-T4-T5-Neo-We...=item3359c87476
Cheers mate, but do you know if the electric window switchs are fitted with this sort of bulb ?
Workshop manula says test the unit for illumination and if operation is not as specified, replace the master switch.
I take then there is no easy way into get to the bulbs.
I have difficulty seeing the petrol flap release in my MK IV, not sure if it is illuminated or is my eyes going.
