Changing Brake Hoses
BillNick
Hi all,
I have Goodridge lines ready to go on this weekend.....when I bought them a while ago I found a guide posted by someone on swapping the lines but cant find it now?
Anyone know the link or have one of their own?
Gonna be renewing brake fluid when I do this to....any advice? Or just simply bleed brakes until clean fluid appears at each corner?
thats the one....muchas gracias!!
does anyone know the procedure for renewing brake fluid?
do you just simple bleed the system using a bottle of new fluid and repeat till all the rotten fluid tops coming out?
wonderd were that had gone!!!!i done that walk through on asi's car.
just keep bleeding till the clean fluid comes out the 4 bleed nipples.
