Damp-Looking Spark Plugs
BF03
Here's a pic of my six plugs in order going 1 to 6. Normal IS200 but runs on LPG. So plugs 1-3 are the right colour, but it just gets worse towards plug 6. Is that oil I see? or just un-burned hydrocarbons (plugs removed from a hot engine).
sparkPlugs1_6
Car doesn't idle right, MOT failed on fast idle emissions, but still drives smoothly on motorway (so I get 220 miles for £26 on lpg). Previous owner didn't keep 'valve-saver' oil topped up, so it might be burned valve seats, or could be just the valve shims need changing to take up the wear on this 180,000 miler. Best scenario, just needs cam timing adjusted, middling might need a head gasket, worst case could be burned valve seats. Anyway ideas welcome, but I suspect its ging into a garage to sort this.
