Multi-Changer Cable Routing
Hi all.
I have just purchased a 12 disc multi-changer. (Old system has been completely ripped out by previous owner)
And I have a couple of things I need to clarify before I jump into this with both feet.
1. Where was the old Multi-Changer originally fitted?
I have no manuals but I am guessing it went in the space to the right of the boot(The left has the jack in it)
2. If this is the case. Where were the original cables routed?
I ask this so I don't re-route through areas not already been pulled up/or snag areas.
Any help here would be great.
original multi changer was fitted in dash, in head unit itself ;)
and for wire routing - remove rear seats, and in passenger side there are some cables going in trunk, i used that hole. run them along passenger side, begind glove box and wollaa :) Easy-peasy Japanese
