Shake, Ratle And Roll
Today when driving at around 50-60mph the steering wheel was wobbling from left to right at a ridiculous rate. This has never happened before. Do I need to get the wheels rebalanced/tracked or does is indicate something more sinister....
cheers
Problem solved, Apparently I have a ruined caliper. Its sticking on the near side. which has therefore caused the disc to warp.
New caliper ordered along with mintex discs and pads. Hopefully that sorts the problems out, otherwise i shall be annoying everyone again.
sorry that was £110 for the caliper including fitting. I should be more clear.
Got the pads and front discs off eBay for £89 i think it was. Was toying with the idea of fitting them myself but I dont trust myself to fix something as vital as the brakes. don't fancy them failing at 80mph on the motorway cause i didnt tighten something correctly.
