Depo L.e.d. Brake Lights
I am thinking of installing these soon and wondered what steps I need to take to prevent the dreaded dash board warning lights popping up as I have experienced this in the past. Also once I connect these to the existing bulb holder do I push the wires in the housing and secure the bulb holder as per usual??
Pic taken without flash
With flash
you need too buy 4 load resistors....2 per light(eBay is your best bet)one on the side light feed and one on the brakelight feed...
the new light just plugs in mate...
Ormi,
Yes I know they just plug into the existing bulb holder but I wondered do I just leave them as they are or do I secure the bulb holder to the brake light housing. I am worried if I don't water may get in.
Any details/links on the sort of resistors I will need?? Any information you can give will be appreciated.
Mars
OK I will try them first. I had problems with the first set I bought some 5 years ago and they were replaced under warranty as some of the LEDs failed but they were also showing a dash board warning light at the time. I actually bought them from a LOC member trading on eBay (Scorcher), don't know if he is still a LOC member. So these lights are new but I have actually had them for 4 years and not used them so the questions is I don't know if they do have the resistors built in. Once fitted I will let you all know how they perform.
  • 5 months later...
