Big Problem With Lexus
donyaz
recently bought a lexus is200 x reg..when i went to buy it..was starting perfectly fine throught the night
until the morning came where it would not start. me and my mate push started the car and it came on. then i thought
it might be an immoboliser problem but the car wouldnt push start if it was something to do with the immobliser would it.
then took it to a few garages they all said..it could be starter motor..battery or alternator..no solution has been found, also the car
is very hot from inside by da cassette area. if you leave the car off for a hour or so, it will not start and will need a push start to work.
jump start did not work aswel so it cant be Battery. help needed please thanks
jump start did not work aswel so it cant be battery. help needed please thanks
Does the engine turn over when you turn the key to start it? Or does it click? or does it do nothing?
Do the dash lights come on?
When you push start and it goes, do all the lights on the dash go off that should go off?
A few more details will help diagnosis.
when i turn it into ignition, all the lights come on and go off, then when i turn it to start engine, there is no sound of the engine
it makes no sound..when you push start it all the lights come on as normal then go off as normal. then once you take it off and leave the car for a bit the same problem occurs and will only be restarted by pushing it. thanks
