Noise Coming From Rear Discs
Bobba77
I replaced the rear discs on my is two days ago (Mintex pads and disc set). Quite easy to do, not the horror show I was expecting. Anyway everything went well brakes are spot on handbrake is only 3 clicks etc. However driving home tonight with the window down I heard a skimming noise coming from the near side rear, only when I turned the car to the right. I'm presuming its rubbing against something as it makes no difference when I brake...... any ideas
This sounds similar to something I had too.
Just done bit of a search again and found the thread I referred to at the time.
Some useful pictures show precisely where problem could be coming from.
This may be an interesting read ...
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=23405
Or maybe the backing plate just needs a shove away from the disc - an easier option first :unsure:
Very irritating those scraping noises :wacko:
Best of luck
TG
Thanks for the reply, Interesting read. I don't think it could be the wheel bearings, convinced its the disc rubbing against the back plate. Also the anti-squeal spring is missing from the caliper on that side, don't know if that has anything to do with it?? Is it possible to buy a new one of these???
Took the wheel off today to have a look, as i said previously the anti-squeal spring was missing. The pads in the caliper are very loose because of this i could wiggle them around. Rang Lexus parts and have ordered a new spring. Should be here be Tuesday, cost £5.20.........
The anti-squeal spring was delivered by Lexus Newcastle this morning ( free of charge very nice of them ). Fitted it and after driving around for 10 mins the noise has totally gone. Glad it was nothing major!! :backofnet:
