Damage
lex11
Hi there. I've hit the kerb side on coming off the roundabout with the LHS rear wheel at speed. Rear wheel is now bent. No damage to a tyre or a rim. :-( Looks like something is bent. Did anyone had similar problem? And how much could that cost to repair? cheers
There is no heavy damage to a car. Only LH rear wheel is pointing right. Had a look underneath and i cannot see anything broken.
you have probably bent the suspension arm on the rear, it will be difficult to tell unless you get it up on a ramp.
Is that suspension arm has to be replaced? Or can it be repaired?
replaced i'm afraid, IF it is that( sounds like it if the wheels sticking out at an angle) there is probably damage to the surrounding area as well, wheel bearing etc. but best to have it looked at by a mech.
Yeah. Lets hope that only damaged part is the arm. Did drove it since it happened and is not nice or safe. Will get it checked out. Upper or lower suspension arm for the rear is around £45 on eBay so lets hope is only that.
Thanx for your help m8
