If I Don't Use My Headlight Washers...
My TTE bumper is on the way, and I've decided I'm not going to bother re-fitting the headlight washers as I never use them anyway, and I want a nice clean look aswell.
So I'm assuming the first step is to plug the pipe that fed them so all my washer fluid doesn't drain out. But is there a fuse/relay I should remove if I do this?
Because I don't want to go blowing up all my pipework if I accidentally press the headlight washer button with the pipe plugged...
