Is200 Dead As A Dodo! Help Please X
andyox
Weve got an IS200 2001 and since the snow its has not started. We have taken the Battery off,charged the Battery, changed the 120amp fuse (which had blown), but still no response. All dash lights are on, but when you try and turn it over nothing happens APART from a clicking noise near where the starter relay is. There is also a small clicking on the drivers door too.
We have taken the starter relay out and bridged the terminals and then it turns over but doesnt start.
Also on the Temperature/Clock screen all it shows is the letter E.
Would be really grateful for any ideas!!! xx (Could this be an immobiliser issue)
Many thanks
Chelle xx
if the 120amp fuse has blown you have but the Battery on the wrong way or you have tryd to jump the car with the jump leads the wrong way no other way that fuse could blow!!,sounds like their is more fuses blown..have you checked all the fuses?under the bonnet and in the car?
if the 120amp fuse has blown you have but the battery on the wrong way or you have tryd to jump the car with the jump leads the wrong way no other way that fuse could blow!!,sounds like their is more fuses blown..have you checked all the fuses?under the bonnet and in the car?
OMFG!!!!! THANKS SO MUCH!! There was a 20amp one Id missed! Now the car is working fine!!!!!!
One last question though, before all this happened the engine management light came on, and the TRC light flashes. Now car is working again its still showing. Code book suggests Timing Belt, any ideas?
Cheers
Chelle xx
Cheers
Chelle xx
Hi, this morning my TRC light started to flash and then the engine light came on, don;t want to take it to a dealer and get stung, could mine be blown fuses?
No prob not, you need to get the fault code read to find out what it is, any mechanic should have a code reader
Ok Thanks, I'll take it to garage tomorrow, would you advise driving it or getting it towed? (about 5 miles)
Just soundsa bit low powered and jumpy, no smoke or anything...
