Wing Mirrors - Reversing Auto Lowering
Hi everyone,
This has been raised before - but no resolution as far as i can see.
Reversing - is it possible to lower and then lock the new position of the wing mirrors in memory ? mine will lower further manually but i cannot see how to save the setting [if possible]
my car is a 2006 IS250 SE-L.
Try moving the mirrors fully up then fully down a few times. Mine were only moving downwards by a small amount before I read this on the US forum. Now they both dip more than enough to see the pavements
thanks F.A,
tried that but they still park a little higher than i'd like; they certainly aren't seized up - I'll ask the dealer about it next time i'm over there.
thanks F.A,
According to the manual for my IS250, the mirrors will not dip when reverse gear is selected if the mirror adjustment selector switch is in the central (off) position. It has to be in either the L or R position.
