Pivot Engine Start Button
GXE10
It is a 3rd party starter button which replaces the 'ignition' from the barrel to an aftermarket fitted button. It looks similar to the S2000 starter, but I would not know where you could fit it on the IS dash, as it would require a large hole drilling.
AHH, I thats what i thought he was referring to, the "pivot" is the bit that confuse's me
I believe that is the Manufacturer.
i just want to know will it disable my immobilzer?
The key will still have to be in the ignition, so it should not effect the immboliser
