How Do You Change Rear Number Plate Bulbs?
remove the cover from the boot lid you will then see a row of 10mm nuts the same hight as the number plate lamps remove these then pull off the lamp cover on the outside of the boot you then slide the numberplate bulb housings to the side they then pop out and you can get to the bulb..
