Is200 Stereo
paddyg
Could you explain briefly what i need to do with said tools
The link below is for the climate control panel but the principles should still apply for the stereo:
http://my.is/forums/f90/how-change-climate-control-center-console-leds-pics-360155/
If that doesn't help do a search, I'm sure someone did a write-up about it...
What if you have a sat nav how do you get it out then?
sat nav removal is the same but theres a trim at the top of vents to remove and under it are 2 screws to remove and then lift and pull towards you.
