Battery Question
GWilso
Hi, 05 IS200
I've noticed on the dash Battery indicater that the the needle sticks nearer to the 9v (about 10-11v) rather than the usual half way between 9-18v is this just a sign that the Battery needs changing? or does it indicate something else? advise as always deeply appreciated
Regards
Gordon
Hi, 05 IS200
I've noticed on the dash battery indicater that the the needle sticks nearer to the 9v (about 10-11v) rather than the usual half way between 9-18v is this just a sign that the battery needs changing? or does it indicate something else? advise as always deeply appreciated
Regards
Gordon
It could be a failing cell in the Battery, the alternator/charging circuit, loose belts/wires/connectors or even just the Battery indicator. With winter coming up and if the Battery is getting on; it is probably worthwhile starting by replacing the Battery or at least trying a known good one. Battery tests at well-known outlets may not show up faulty cells or other Battery faults until the Battery is seriously stuffed.
