Clutch Squeak
AYP
I have a 5 yr old IS220d low mileage(50k). Clutch has developed a squeak when the pedal is pressed down. It started doing it just when it was cold but has now started doing it when warm too. It sounds like a squeaky spring. Any ideas what's causing it? Hoping for a cheap easy fix otherwise the car's going - fed up of expensive problems with it!
Many thanks
Got the cheap fix ... a can of WD40 did the job! Squeak has gone & clutch feels lighter.... so the car gets to stay for now!
  • 5 months later...
Sorry to be the bearer of bad news.
I have just had this issue sorted by a Lexus dealer near me in Essex as I could not put up with the squeak any longer. I am now £1,500 lighter for it!
The clutch is fixed to a fly wheel which are both still under patten, so you can't get from anywhere but a main dealer!
Clutch £863.00 and the fly wheel £925.00!!!!
When the dealer see my eyes popping out in rage they reduced it to £1500.00 which I was still not happy about.
However, my car does not squeak anymore or do I have trouble getting it in reverse anymore.
Hope this helps.
  • 4 months later...
sorry, I know old post, but you paid what? Eurocarparts have the clutch kit at £198 and flywheel at £838, even found a new clutch an flywheel on eBay for £795.
Still a lot though, my clutch squeaks too, but I hope it doesn't come to this, but a lexus dealer won't be touching my car at those prices.
  • 2 months later...
I'm experiencing the same issue on my 2006 IS220d and considering having my dealer have a look at it.
Is it possible the squeeky clutch problem is similar to what the guy in this video is fixing on a Corolla?
