Was wondering has anyone fitted a tow hitch to an RX450h AWD SEI Lifestyle. It has the Lifestyle under trays fitted and I have been told they these are not compatible with the towbar including the removable hitch version. I was wondering if a cut out could be made so this could be fitted with the hitch.
Any help or advice would be appreciated
Regards
B
That's the hitch I was thinking of fitting, however My RX has the lifestyle pack which has an additional silver coured undertray which looks like its fitted on over the standard set up. I am trying to figure if this can be cut to suit the bit h. If you had a picture of your hitch installed it would be a great help in trying to see space around hitch etc
B
  • 4 months later...
I have a witter removable tow bar fitted to my RX450, they cut the under tray to fit and allow the lights accessible.
If the under plates are metal it might be an issue
are your light sockets retractable/hinged so you see nothing when not in use?
