Rear View Cam
Hey Red-lex what ipod dock is that, and have you run it through a grom kit?
If so, did you have any probs with doing so, i cant find any docks that work with it so far!
Hi Jomo, it's a brodit cradle like this one:
http://www.ebay.co.uk/itm/BRODIT-PROCLIP-915290-PASS-THROUGH-HOLDER-iPHONE-3G-/150733816985?pt=UK_Mobile_Home_Phones_Bluetooth_Acc_ET&hash=item23186f8499#ht_1184wt_1325
I have it connected to a Xcarlink which is similar to the Grom kit and works perfectly. It should work fine with the Grom too as it's just a pass through connector? I only chose the Xcarlink over the Grom as I found a used one on eBay, along with the Brodit cradle and Nokia CK7W.
  • 2 years later...
In relation to this topic. I have a year 2000 lexus is200 SE . It does not have the central sat nav display on the dash. I upgraded the stereo to a two din one but did not buy one with a display so need a different solution. Has anyone attempted to install one of those digital rear view mirror (RVM) displays that click onto the RVM? If so can anyone suggest a model to buy just so I know what is compatible please?
