Is220 D Headlights
Dave_Notts
I would check the handbook to see what the standard bulb type is then look for a good quality HID conversion kit.
If the original lights are not projector types the beam pattern from HIDs is quite splattered and may require realignment of the headlights to compensate a little for this and also bear in mind there are new MOT requirements for retrofit HIDs.
