Power Steering Belt, How To Tighten - Advice Needed
look at the power steering pump youll see a 14mm bolt thea goes in from the rear up the top slacken this get a lever tension the belt then tighten the 14mm back up job done...i would take a pic for you but my supercharger is in the way...
