Engine "hunting"
kenfoxy
If I pull away with minimum revs, the engine "hunts" for a while. The rest of the time the car drives perfectly. It has always done it to some extent but it seems worse now. Has anybody got any ideas?
I clean the carb on mine with a carb cleaning spray from Halfords - not had an issue with it in the 3 years i have used it - nothing promped me to use it, i just wanted to make sure car was running ok. I did note however that after use (on each occasion) that the engine management light came on - i was told that this would go out within a few hours when the spray evaporated away from the sensor in the carb and it did. I just sprayed the aerosol into the body and wiped around the rest.
Its a 10 minute job that will help to narrow down the problem and also clean out the carb body but be careful if using wipes not to drop any into it.
I had the hunting problem on an Astra i had and found it was the airfilter along with the air mass meter that had blown (so i was told) - i replaced the filter and as above cleaned the card out and it was fine after that. Not saying the Lex is the same as the Astra but it could be a cure?
At the time of starting this thread, I had Forte Gas Treatment in the tank. Since then I have refilled the tank and added another dose. The car now runs fine so I will keep a watching brief before doing the carb clean.
I bought mine new in 2001. At the time, the only fashionable colours were black and silver. These days ppls taste has opened up and aztec fire is more favourable.
