Link To Frozen Navigation Screen Fix
link to frozen nav fix
Hello TonyGoose, Thank you for putting this link here, did you do this on the basis of my earlier post regarding the repair of the SatNav unit?
The reason that I suggested that someone might be able to copy it and locate it on our forum (rather than via a link) is because in the past I have tried to use similar links only to find that the item had been removed and was no longer available. My thoughts were that if were to be put on our forum permanently then the danger of it being removed from its original home (i.e. Club Lexus) would not be of concern to us.
As I mentioned in my original post, I am no computer wiz so don't really know if it is possible to copy it.
