Dials And Clocks Won't Light Up
Shreksta
I've got the autolead installed to DVD head unit and had problems with car Battery not starting today so I thought it could be constant connection. While installing a switch one of yellow wires connected to casing and dash lights and clock went off. Fuses seem ok and it will come back on when link it to other yellow but remain on constant so put them on a switch for a temp fix. Need help please.
Good news,care to elaborate on the cause, my guess is you missed a blown fuse?
It's always a good idea to disconnect the Battery negative lead when doing an electrical work on cars, I've seen some nasty results if the circuit isn't fused!
