Outside Rear Door Trim, Help Needed
Hi guys.
The rear outside trim on the door fell off the other day, ive put it back on with double sided sticky tape, but the same thing is happening again :-(.
I noticed on the back of the trim there were gaps, as you most probably know its not a solid unit, so the tape doesnt have alot to adhere to. Does anyone have a remedy for this, as i dont want it falling off as im driving :-(.
Thanks in advance.
hi you could stick it back on with tiger seal you can get this at a panel and paint shop as body shops use this to fix panels on with just make sure both parts are clean before applying hope this helps
