Parrot Ck3100 Handsfree Kit
Phil-lancs
Hi guys,
I've just purchased a Parrot CK3100 hands free phone kit. I have the appropriate ISO lead to connect it to a lexus IS200, however, the reason for the post!
1. When looking around the audio system and the underside of the dash it all looks very tight! Has anyone any tips were to place the 'blue box' etc?
2. To connect the wire for the kit do I need to remove the audio system? Is there an easy way??
If anyone has installed this system to their IS200 i'd be very interested in hearing from you with your advice :)
Thanks, Phil.
The blue box fits just above the climate panel underneath the NAV screen or tray.
The SOT lead connects to the AMP behind the glovebox and leaves you not a lot of room to run it to the blue box. An ISO extension lead would do here.
