Ipod And Bluetooth Handsfree
I have the Grom Audio unit, the good is OEM look and Bluetooth to phone for calls/audio. Bad is sometimes if I turn the ignition on too quickly and got the car started, seems like the Grom unit doesn't have enough time to startup maybe, then the CD changer unit doesn't recognise the Grom. The only way to resolve is to turn car off and on. Since it is bad to turn a cold car on and off, so you end up with listening to CDs and radio for the trip.
  • 5 weeks later...
Guys...how on earth do i get the bottom console out, the one with the heated seats and traction button?
I've seen lots of videos of people just yanking out the plastic, the problem is that there's nowhere to put your fingers to pull!
Help please! Thanks.
Wet your finger tips just a tad. Place your open hand up against the underside of the shroud holding these buttons and with upward pressure slide it forward. Once you've done it its easy.
