After Market Radio
Where did you take your feeds from (if any are different). Could you have blown any fuses while cabling up?
How's your Battery power? Do the lights dim dramatically while you are attempting turning the engine over?
Thanks, I will check the fuses.
I needed to be a little more specific...my fault. I had only pulled out the factory radio and went inside to get the after market radio....when I went to get in the car the alarm went off and i put the key in the ignition and it stopped the alarm, but then the car would not start up. At that point I had not put in the other radio or ran any wire or changed anything...just pulled out the facotry radio???? that is what is puzzling me! :angry:
