Headlight Aim Switch
the headlight aim switch to level the lights up or down does not light up.
I thought its the bulb.
I have changed the whole switch from dealers with the bulb and same problem.
is there a separate fuse for this ?
hi I am not sure if it actually does light up as not all of dash switches do,will check and let you know if someone doesn't before I get back to you,don't think it has a separate fuse either.
Can't help with fuse location as not listed as seperate, i think it's covered by dash illumination fuse.
All i can say is mine lights up.
mine use to light up before.
its got a bulb in the switch which I replaced, still did not work. so then changed the whole switch with bulb from dealers.
its not a big problem but annoying when all the dash lights work and light up apart from one -
think will browse through the fuses, its all I can do I guess .
