New Brake Pads On Is200, Squaking While Driving...
AIC
Having issues with a squaking noise while driving. My old pads were really worn so I ordered a set of EBC Ultimax for all four corners. The rear rotors are OEM and have 20.000 km on them - hardly a groove in them. But I'm getting this really annoying "tiii tii tii tii tii tii tii tii" while driving from the right side (rear). This stops while braking actually. There's no pulsating action in the brake pedal nor steering wheel while driving nor braking. I've also checked and cleaned the hub behind the rotor.
Is the rotor warped?
Is there a warranty on the OEM rotors, "x" kilometers?
Would a rotor swap do the trick or should I have a shop turn them for me?
Should i get OEM's again or after market ones?
What are some good brands after market ones?
From what yoyve already checked i dont know what else to sugest tbh. Alot of salt on the roads this time of year that can get stuck somewhere
Check to see if there is any corrosion/rust on the disc just below or above where the pads make contact with the disc, sometimes if there is a rough rusty surface close to pad contact this can cause a variety of noises. Also check the back plate behind the disc is clear of the caliper and disc.
