Same with mine at 20 years old, 2 advisories the 1st year front discs and brake hoses, never replaced and never mentioned since (fast fit centre looking for work?).
Failed once on lower front ball joints so replaced with OEM parts.
Discovered excess play in nearside upper control arm balljoint this year and replaced with OEM before MOT and went straight through again.
Quite look forward to taking mine for it's MOT knowing it will more than likely pass with a clean sheet.
