Charging Battery
sparky64
I was always wary about doing this as in the old days it could blow a diode (or two) in the rectifier. Apparently that's now not the case and it will charge very well while in situ in fcat I have done mine recently due to the slow Battery drain and little car use. It charged very well. One thing I have read is to limit the charger to under 6 amp. Mine is only a 4 amp Battery charger so no problems even at the start of a charge with a low Battery.
