Petrol Gauge Problem?
Galee
Hi I have a 1992 Soarer 2.5 TT Auto in Pearl white But I have discovered the petrol gauge is not working when I put the ignition on it flashes for a bout 3-4 mins then just reads empty all the time even when I fill it up it stays the same has anyone every had the same problem or know how I can fix it?
Thanks for any help.
hmm I am wondering if you are suffering from blinkey dash.. very common problem in soarers.. nearly all have it
does the odometer work? nothing else flashes?
If it is blinky dash then I know someone that can fix it for good.. but its about £150
other places charge £400 +
or if you electronically minded then you can do it for about £4.50 if you are really good with a soldering iron. But once its starts it does get worse. If you do solder it yourself and break it then its a £2K part!
Hi No it's not blinky dash I had a soarer last month that had blinky dash when you turned the ignition on the odometer was fine then I would suddenly go. I did manage to fix it myself by soldering in the capacitors and transistor. But this is just the petrol gauge and nothing else just wondering if it could be a faulty sender unit?
Galee
hi galee
i would think you are on the right track looking at the sender unit first
i have never tried to get one out of a soarer yet but i wouldent think it is to duificult. if you don,t want to tackle it yourself pop it into a toyota dealer and get it checked out,
regarding blinking dash my 4ltr gt/l has just developed it and i am going to tackle it this weekend , got all the bits from maplins , and am going to change all the capacitors as the chances are they are starting to break down . i'm also going to clean all the mirrors and screens , and check out
the lamps .
i have got a comprehensive set of instructions copied off the australian soc
including how to drop the steering wheel etc
