Can anyone help as this is just silly.
The beeps are so quiet!!!! Everything has been turned up and Lexus have turned up what they can but just a mouse like beep that's drowned out by the fan let alone any music - Any Ideas?
M
If this is the 3rd Gen GS300 then I may be able to help. I was fiddling with my display yesterday and if you press "Info" and then "Parking Sensors" then "volume" is the first option you come to.
Thanks for the input, But as I have said in the original post ALL of the settings have been set to maximum. Anything else it could be? I was wondering if there was any soundproofing that may be blocking the beeper - Does anyone know where the beeper is located as I would like to see if anything is blocking it.
M
I also find it very quiet (along with some other beeps) with volume set to max, and being a little hard of hearing doesn't help. I wonder if there is a setting (maybe Lexus can only change ?) to raise the volume.
Lexus have told me that they have no way of adjusting this. I was thinking that it might be soundproofing in the way as the sound is still clear so not a failed beeper but is very quiet (cant be heard over the fan on 25%)
