Reversing Camera
Hi I've seen lots of post around this subject but just need confirmation about something.
Can I use the standard sat nav that came in my is200 ?
I'm fine about the wiring of the camera it self, but is it a case of simply plugging in the camera to the sat nav ?
it isn't that simple,The IS200 nav unit wasn't designed to have a reversing camera. You can tee into the video feed from the sat nav but you need to sync the video correctly, have a camera that has an inverted output, have a mechanism for switching the video source etc.
Ok thanks got the definitive answer. will have to replace the sat nav with a monitor that will work with a reverse camera. Any suggestions on what size / make of screen is the best option, minimum modification of the housing ?
  • 5 weeks later...
