Hi very quick couple of questions hopefully someone will help me with, here goes. Do the headlight washers on a 2000 GS300 have a fuse? If so, Where is it located? Thank you
Oh, tried search facility couldn't find anything and in manual, doesn't tell you. Thanks again
Yes the system uses both the Washer and the H-LP CLN fuses.
The H-LP CLN fuse is a larger square fuse not one of the smaller rectangular ones. I believe it is located on the fuse box near the bulkhead in the engine bay on the drivers side.
Remember that your headlights need to be on before the washers will operate.
post-3469-0-60726100-1405971544_thumb.pn
That's something my local MOT station haven't seemed to work out. Twice they have failed my GS for them being inoperable, which I then end up showing them as working fine as soon as I turn up to pick it up.
