Is200 Tracking Settings
kev dood
A while ago I posted the tracking settings, which I also think Rodders (?) put in the knowledge section.
Anyway, I had also emailed Lexus GB about these and they have come back with some slightly different figure!!
Mine I think originated from a mixture from mainly Javadude and Supracharged IS340. Maybe there are differnent settings per different model years, see email below.
Original settings from Javadude etc etc. are...
FRONT
Caster Min = 5 deg 16', Max = 6 deg 16'
Camber Min = -0 deg 51', Max = 0 deg 9'
Toe Min = -0 deg 6', Max = 0 deg 18'
SAI = 9 deg 16'
REAR
Camber Min = -0 deg 53', Max = 0 deg 7'
Toe Min = 0 deg, Max = 0 deg 24'
Lexus GB sent me this email.
Dear Mr Dodd
Thank you for your enquiry concerning the wheel alignment for your car. I
have checked this will the head office technical department, and for the
following car -
IS200 SE  reg: removed  Vin: removed
the specification given is -
FRONT:  Caster  5.46'  +/-  30 mins
Camber -0.21’  +/-  30 mins
Toe 0.6’    +/-  12 mins
REAR: Camber  -0.23’  +/-  30 mins
Toe        0.12’  +/-  12 mins
If I can be of any further assistance please do not hesitate to contact me.
Kind regards
Stuart McGregor
Lexus Customer Account Manager
Can anyone shed any light on these, as the front camber settings for example, differ quite a bit!
Also, what is SAI??
They both read the same to me :blink:
One gives the maximum/minimum figures and the other gives the mid point and the allowed tolerance each way.
I think the Lexus way of writing it is perfered as those are the figures you should be aiming for when adjusting.
