Tailgate Not Working
VRF28
Hi all.i have a 2006 rx350 and the electric open and close on the tailgate has stopped working . I asked an auto electrician to have a look and have bee advised the unit has failed and needs replacing. Apart from main dealers can you advise where to have repaired or who else could supply.
Thanks in advance
Thank you for the info. I should have asked the auto technician to remove the unit for me as I would have been able to compare it against one I have seen on offer which came from a 400H same year as my 350se. I was hoping they would be the same. I just have to figure out how to remove the tailgate interior trim.
Thanks for your help.
Replaced the motor still not working. Checked the switch in the glove box still not working so struggling to find which way to go.
Which fuse is used for the tailgate is it one on its own or does it share other lights switches etc.
Nothing happening which ever switch I press.
Any ideas would be great.
