malahai
Steering wheel wobble when breaking.
Hi guys,
I am getting mental with this stuff, so I hope somebody will be able to direct me to some solution. I got my IS200 2004 reg., about a year ago. Back then I changed all pads and discs to some new but cheap-ish stuff, different brand on the front, different at the back. I think at this moment I started to get steering wheel wobble when breaking from about 40-70mph. I did live with them for about 2 months but got annoyed, so changed all breaks and discs, this time I went for full set from Pagid. I realized immediately, that it did not sort out my wobble problem. After some time I decided to finally resolve the problem, took it to mechanic thinking that it might be faulty wheel alignment. Nope, all OK. They said it might be some dirt on front drive hub flange (if I undestood well). They cleaned one (front passenger side) and it was OK - wobble gone. For two days, then it came back.
So now, should I assume that problem might be with those front drive hub flanges? Or maybe calipers, as they are the only part that wasn't changed? Let me add that I fitted set of 4 brand new tires and alloy wheels as well. Any ideas guys? Would really appreciate some help.
As it started when you changed the brakes, I'd go with them being the seat of the problem. My immediate thought was, did you clean the disc to hub faces? Really clean them? As just the smallest bit of corrosion will put the disc(s) out of true.
Remove each disc and get the mating faces spotless, then see how it goes..
Thanks for advice. I guess that this is exactly what mechanics did recently when then took them apart, but as I said, it lasted just a few days and problem came back. Maybe hub faces are uneven and hubs need replacing?
Certainly on my SEAT the service tech docs required both the disc and hubs to be replaced together but I don't think I've read anything similar with regard to Lexus..
Another possibility is disc glazing i.e. pad material gets deposited on the disc face. A couple of hard stops from speed usually cures any wobble for a short while.
You could try reverting to Lexus supplied discs and pads as you didn't have the problem with the OEM brakes?
Hi this is a common problem with this model ,and well documented on here . What I suggest is you go back to your mechanic and get him to check the disc run out with a dial gauge on both discs . If this is within tolerance the problem lies with the calipers and/or pins which will need to be thoroughly checked .If it is outside the tolerance ,he will have to check discs for warping or hubs .When I had this problem on my sport cross I ended up with 2 reconditioned calipers to cure it .
Dave
Hi, this is a common problem with the is200. Its usually the front brake caliper slide pins that have rusted & seized. After cleaning use silicon grease to lubricate. They should slide freely. Hope that helps.
I found the cure eventually - after wasting a set of front discs and one lot of on-car disc skimming - was new calipers and carriers and another skim. Touch wood, 21,000 miles later and no wobble.
  • Similar Content
    • By Blucky
      I have a 1999 Toyota Altezza 1GFE, which recently has had the engine light come on after driving it for a few minutes. Every time i restart the car it goes away but comes on again after a few minutes.
      I have done the paperclip diagnosis on the ODB1 port, but all it does is make the engine light, ABS light and the ECT light flash continuously.
      Does anyone know what it might be?
      Cheers,
    • By mondo35
      Hi guys, i have owened 3 lexus is 200s
      and I absolutely love them,
      just recently i thought about having a caravan so i sold the sport and got the is 200 SE
      I have the tow bar and everything, i want to know how much the standard is 200 weighs.
      as my car and caravan must be 3.5 tonne or under. Now can anybody please tell me how to find this out, i have looked online allready but have had no luck
      thanks in advance for all the replys,
      much appreciated
    • By SHOEY94
      Hi guys,
      first time posting here on this forum looking for help. I currently have a 2000 Lexus is200 as my weekend (fun car) while my daily was in getting repaired I was driving the Lexus as a daily but when my main car came back I parked the Lexus up starting it every so often. Then when I went to start it one day it just kept turning and fuelling but would not spark. I had to charge the battery also. I checked power to cool packs and they all have power going to them. I've checked all fuses and nothing seems at fault there. While I was driving it as a daily the plastic part of my key, which is the only one I have for it, split. I glued it back together but I've a funny feeling this is the issue that the chip isn't sending out a signal. When I put the key in the ignition the red dot security light is not lighting up! Does anyone have any ideas or people who could sort this for me ? I'm in the Meath area of ireland.
      Much apprecited.
    • By Yobosoku
      Hi, new to forum, there may be an already existing thread but I cannot find anything......ANYWHERE! I need an ecu pinout for a 2001 is200 using a 1gfe with an ecu number 89661-53200. I need this pinout diagram and expertese to fit a bee*r limiter basically because I want one and I like being a loon in my car. There are people who hate/disagree with them, however I would like one in my car and I would appreciate help fitting it.
      any help appreciated.
    • By wezsleigh
      Hello im looking to get install a turbo into and IS200 and looking through this forum and various other forums I've not really found a clear answer to my question. Can you just install a turbo onto the is200 without having to buy this £2300 kit? For example, could I just change the manifold and install a turbo without having to spend all that money. I understand that some stock internals may need to be upgraded however e.g. flywheel, manifold and such.
