Verbout
IS 250 Differential Oil
Car passed its MOT the other day, the mechanic notice a noise in the differential when he spun the rear wheels, it’s something I’ve noticed but never done anything about.
A change of oil is called for as a starting point.
Where do you get LT 75W-85 GL-5 oil from?
Halfords stock something similar which is reasonably priced but I can’t find any that meets the exact specifications.
Hi ,I use redline from Opie oils  Fuchs titan sintopoid also listed      great service with a discount
Dave
Dave
Cheers Dave, I’ve looked at the Redline products, not cheap.
1 hour ago, NemesisUK said:
£43, :eek: and I’d need two. Thanks Nemesis,  I’d already found the expensive ones,     :lol:
I was looking for something more reasonably priced.
Found some at Opie oils, it helps if you miss off the first two letters of the code, the L and the T.     :lol:
£30 for 2 litres, including postage.
It’s got all the same numbers and letters, 75W-85.
 GL-5 is mentioned in the specifications section.
It’s going in the diff as soon as I’ve finished decorating.
I’ve sent an enquiry to Opie Ools regarding the letters.
42 minutes ago, Verbout said:
I believe it refers to Lexus/Toyota. Does anyone know different?
The posts in the link seem to suggest 'LT' is for non-LSD equipped cars, 'LX' for those with LSD?
The man at Opie thinks LT stands for Lifetime, but he’s doing a bit more research.
Yep, got that, sorry I didn’t notice the link, thanks.
According to the manual I have to get under the car, the diff should be labelled as to whether it’s an LSD or not.
I would expect a non LSD.
Just got the OK from Opie Oils, the oil I purchased is a replacement for the Lexus/Toyota stuff.
But they had to draw a blank on what LT means.     :eek:
Just checked the service sheet from Lexus-tech.eu for both the RF300h and the RC-F
Just as the post in my link stated. Use the LT for standard or torque vectoring diffs and the LX for the LSD diff
Right, my next question is:
If the change of oil does not quieten the diff, what are the collectives view on using an additive?
The less scrupulous dealer might add some sawdust to the  oil to quieten a noisy diff :wink3:
How long do you expect to keep the car? An additive might be a short term solution but my preference would be to diagnose what the noise is. Might be simply a slight adjustment of the crown thrust bearing.
Haven’t heard the sawdust tale for a while, Arfur.   :lol:.
My car ownership is always long term. What I will do is try the oil change, see how that goes, then look into the internal’s of the diff’, I haven’t had one apart since the ‘70s. :lol:
Thanks for your input.   :thumbup:
