All Activity
- Yesterday
farhan_s1 started following Oil Leak or coolant leak?
I have this is200 1999 its dripping on my driveway. I know i have a coolant leak somewhere as my coolant level goes down. I also need to burp the coolant system as theres sloshing noise. The oil cap is not frothy or anything. Appreciate any help here! IMG_5733.mov IMG_5728.mov
I notice the stag is colour coordinated white with the garage 😉
Bob King started following SC430 OEM Alloy Wheels
If they are the standard SC430 wheels, spec should read .. PCD 5 x 114.3 Diameter 18" Offset 45 spec should be embossed on the back of the wheel spokes 👍🏻
Well it appears not. There is a noted advisory "poss thermostat leaking coolant". Toyota coolant is red/pink, and there is some old staining in the water pump area. Having seen the Car Care video of the water pump replacement, there's not a lot you can do about an overflow when removing it. I'll keep my eye on it. EML - Timing belt issue fixed VSC - Reset yaw sensor Coolant levels, Oil levels etc all good Running bulb replacement (whilst inspecting brakes) Parking Brake adjusted at hub (24 clicks) and pedal My choice of Lexus secret behaviours Thorough visual inspection of brakes and suspension No codes. Paul at ToyotaTech Guilford 5*+ (he's booked up until mid June) Total cost less than 2 hours labour. To do: Tighten roof latches to lessen bumps and creaks. In adding the in-line fuse holder to the radio system, I appear to have resolved the 5A pcb fuse issue, so maybe it was a simple dry joint. I have been in there so many times now it holds no mysteries. The rear seat speaker is underwhelming but overall sound is exceptional. The "secret" switch in the armrest is bypassed currently. It probably requires something of better quality. It is 12v rated but has 3 pins. There is an LED which oscillates dimly when in circuit. Every time I use the switch I need to recycle the ignition for the system to wake up. It is probably too clever and reacts to increased resistance or voltage drop. I'll research it more as I hear the CD stacker travelling even without the ignition key in place, so it must add to parasitic drain. Re-load the extending aerial. It sticks up around 1" which obviously allows fod and water ingress 24/7... Cosmetically she's in good shape. I do need the passenger triangular sweeping panel adjacent the parcel shelf (maybe both would make sense). Front drivers reflector is cracked and needs replacing. I removed the rear lamps to clean any gutter debris behind them and the drivers side fixing is a rusty bolt without a cover, definitely a replacement. The drivers door threshold panel is also unsightly with a big scuff mark across the illuminated Lexus logo. All seats could do with some colour, particularly the flat seat sections, front and back. Whether this is dull due to sun bleach or water I don't know. I have some leather feed from Halfords, but it is clear and I have no experience of its effectiveness. I do have some LiquiMoly Gummi-pflege so will treat all the rubber seals once the rain subsides. Can't wait to get some miles under the belt
Coilover spring rates
jeffrosie6 replied to jeffrosie6's topic in Lexus F Club - Lexus IS-F / GS-F / RC-F Club
Not a problem buddy. That's exactly what I've been doing. Heat and penetrating fluid. Using a 50/50 mix of diesel & aviation hydraulic fluid as that's what I've read that the RAF mechanics used to use to good effect. Got them more or less freed. Fingers crossed the rears are good. -
Considering it's an outside car and we've had a cold, wet and windy winter. the 10yr old CT still brushes up ok with a decent wash down. Ready to go for another year now, MOT, Major service, Lexus Roadside, new 3yr fixed price service contract and the 11th year of Relax warranty. all done and yet another year of completely trouble free motoring. This car never ceases to amaze me.
Jgtcracer replied to jeffrosie6's topic in Lexus F Club - Lexus IS-F / GS-F / RC-F Club
Sorry for only replying now but wouldn’t expect a good mechanic to struggle, particularly if you took them off the car in advance. Having the right tools and a strong vice makes all the difference. From experience galvanic corrosion could be the issue but isn’t something some penetrating fluid couldn’t sort…. -
I'll let you know how i get on then Don. Appreciate your input
My test drive experience
Don C replied to Icebun's topic in Lexus LBX Owners Club - The All-New Lexus LBX
I came from a Cross and it was noticeably higher than this UX. Nowhere near the quality though. -
If you can’t do it, meet me back at the same place and I’ll do it with my scanner. They sometimes take a good drive to settle down.
The term isn't what people mainly associate it with. I quote; Badly or hastily built with materials of poor quality. The term is mid 19th century, and is sometimes said to be from the name of a firm of builders in Liverpool, or to allude to the walls of Jericho, which fell down at the sound of Joshua's trumpets. From: jerry-built in The Oxford Dictionary of Phrase and Fable »
Spottedlaurel started following RX 450h - what is a 'normal' mpg return?
Unless you're doing 50-55mph on a motorway and can manage doa bit of coasting it's unlikely you'll see an improvement there. At 70 you'll just be running on the petrol engine all the time. I normally get an indicated 34-35mpg, on a mix of 50mph A-roads and tootling through towns and villages at 20-30mph. That's after 5+ years of getting used to it.
Hi all, The time has come for me to sell my GS. It is the best car I have owned by far, but it is time for me to try something different. I will skip listing all the gadgets as I assume most of you know what the Premier trim has. I have owned the car for two years and have done: - Major service at Lexus at 96,000 miles including all fluids (engine oil, gear oil, brake fluid, coolant, all filters) - April 2022 - Service in May 2023 (independent garage) - Rear brake disks & pads - November 2022 - Rear tyres - Good Year - November 2022 - Fuel pickup pipe recall completed - May 2023 - Serviced today - 25 April 2024 (independent garage) The car comes with: - 12-month battery warranty by Lexus - until 18/04/2025 - MOT until 17/11/2024 - no advisories - New service - done on 25/04/2024 Imperfections: - Chip on the windscreen. It is repaired but still visible. It doesn’t affect visibility or MOT (it was never advised) - it is behind the rearview mirror. - The wheels have some curb marks - particularly the rear right wheel. The car is going to the body shop tomorrow (26/04) to get a couple of imperfections sorted and I will be posting it on Autotrader later tomorrow. The price will be set at £9,795 and will be non-negotiable. I have described the car as well as I can and at this price it will be the best value GS450h on Autotrader. Adding a few pictures here - I will upload more to the Autotrader ad tomorrow. Thanks, Boris
Cocodotje joined the community
May I have the temerity to correct your statement - " Certainly not old Lexus standard! When we lived in France I used to wonder why people used to say "Jerry built" when you see the build quality of French houses???. They don't even use bricks or foundations or gutters need I go on.....
Thanks for the advice and comments. I’ll call into my local-ish Lexus dealer next time I’m passing to find out if they’re heating elements or not and take it from there.
I'm selling them for an ex-owner He's beyond retirement, and doesn't have the car anymore , no tyres just OEM , I believe they are called 18" Soarers
Not sure, but offset is 5x114.3
My nephews Range Rover new bumper whatever, slight damage really, the insurers agreed for the repairer to use 2nd hand from a Breaker / TheBay rather than wait forever, indeterminate months, for brand new ……. he just wanted his car back on the road ok and useable …… just a month out of action rather than forever …..,, practicalities eh ! Malc
Having paid out for an AC condenser for that very reason, I’ve certainly thought about it, but haven’t actually done it yet. I’m pretty sure someone on the 300h forum has done it though. I’d maybe go with a fine aluminium mesh rather than plastic.
Well i tried the TPMS reset via the settings and no joy unfortunately. God only knows what the tyre place have done?!?! Anyway it's booked back in tomorrow for them to have a look at it. Fingers crossed🤞🏻
My beloved CT is in for a new rear bumper and tail light (through insurance). They agreed to pay for and use genuine Lexus parts. Called up today for an update, they're still waiting for parts. Do any of you have any industry experience or body repairs that would know roughly what sort of lead time it takes to get genuine parts? I once waited two months for two new doors and a bumper to come from France for a DS3. I hope it's nowhere near that long!
Hi Stephen glad to see my old car is going to some nice places👍 looks good have you done much to it? My brother has recently bought a stag, having driven that makes me appreciate just how good the sc is, one day I will have another sc perhaps, hope you are being careful with that throttle booster😀Stew
