Snow Switch
captaindsc
well the topic says it all really,
what does the snow switch do exactly on the vertex.
I thought I better find out before the snow comes.
I noticed that the abs does not help the car much in the frost, it just stops you braking.Does this switch compensate somehow and when should it be used, eg can you drive on the motorway with it on or is it only for low speeds.
If you keep moving the throttle pedal snow mode will help as small movements have less effect.
I also find snow mode useful in very heavy traffic, makes the car smoother to drive.
With cruise set, snow mode shouldn't make any difference as the car still has to maintain the speed and this will require the same amount of power. I find that I can drive more economically myself than the cruise control however if your not careful you start to increase the speed.
