Headlight Washer Not Re-seating Correctly
Good morning,
The rhs headlight washer does not seat correctly after use. I have sprayed it with WD40 and it pops down when I push it, do any of you know what I may have to do to fix it? I don't particularly want to take it to a garage unless I have to. Could it just be a worn spring?
Any advice gratefully received
John
The actuators, whilst not sealed, are a self contained unit. A garage probably isn't going to attempt a repair, just replace it for a vast some of money. If WD40 doesn't work then you could try dismantling yourself to clean it up but that in itself is quite an undertaking as I believe the bumper needs to be removed to be able to gain access.
